hm_getdefaultcardimage
Returns the default card image for the specified entity type for the current template/profile.
hm_getdefaultcardimage entity_type
HyperWorks Tcl Query Command
Returns the default card image for the specified entity type for the current template/profile. No value is returned if there is no default. The default card image is used by *createentity when another card image is not specified.
entity_type
The type of entity to query. All entity types are valid.
To get the default card image for properties:
hm_getdefaultcardimage props
   # Handle error
Version History
14.0.120
