hm_getnodegeometry
Get the simplest geometry entity associated with the node.
hm_getnodegeometry nodeID
HyperMesh Tcl Query Command
nodeID
The ID of the node.
List containing two values. The first value is a type of geometry. It can have a value of none, point, line, or surface. The second value is an ID of the entity.
hm_getnodegeometry 1
returns:
none 0
If the node is associated with more than one geometric entity, only the simplest one is returned by this command. For example, using this command for a node located on the edge of a surface would return "line" and the line’s ID, because the line is simpler (fewer dimensions) than the surface. (A corner node would return a point because the corner is a vertex.)
None.
