hm_holedetectiongetnumberofholes
Returns the number of found holes/tubes.
HyperMesh Tcl Query Command
Returns the number of found holes/tubes. This must be preceded by a call to hm_holedetectionfindholes.
To write out all geometric shell hole details to a file named C:/temp/holes.txt:
set holesfile [open "C:/temp/holes.txt" "w"]
hm_holedetectioninit
*createmark surfs 1 all
hm_holedetectionsetentities surfs 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
set n [hm_holedetectiongetnumberofholes]
if { $n > 0 } {
puts $holesfile "Number of holes = $n"
puts $holesfile "Holes details"
for {set i 0} {$i < $n} {incr i} {
puts $holesfile "i = $i [hm_holedetectiongetholedetails $i]"
} else {
puts $holesfile "Holes not detected."
hm_holedetectionend
close $holesfile
   # Handle error
Version History
14.0
