hm_entitycanselectby
Returns true if the passed entity type can be selected using the specified advanced method.
hm_entitycanselectby option entity_type
HyperMesh Tcl Query Command
This command returns true (1) if entity_type can be selected with the specified option, else it returns false (0). The valid values for option are the same as those in hm_appendmark, hm_createmark, *appendmark and *createmark.
To determine if elements can be selected using the "by name only" option:
hm_entitycanselectby "by name only" elems
   # Handle error
If entity_type is invalid, you will get the following error:
hm_entitycanselectby: invalid entity type specified.
