hm_getprefixbasenamesuffixforgivencompname
Returns the split name as prefix, base name and suffix for the specified component name and separator.
hm_getprefixbasenamesuffixforgivencompname name separator
HyperMesh Tcl Query Command
name
The name of the component.
separator
The character to be used to split the component name. The prefix is everything before the first instance of this character, the suffix is everything alphanumeric after the second instance of this character, and the base name is everything in between.
Examples
To get the prefix, base name, and suffix for a given name using - as the separator:
hm_getprefixbasenamesuffixforgivencompname abc-defgh-ijk.123 "-"
  {abc defgh ijk}
   # Handle error
Version History
2020.1
