hm_modent_getentityparent
Returns the hierarchical modular entity parent of a specific entity.
hm_modent_getentityparent entity_type entity_id parent_entity_type
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
entity_id
The ID of the entity to query.
parent_entity_type
The type of parent entity to query. Valid values are subsystemconfigurations, subsystems, and subsystemsets.
Examples
To return the parent subsystem of component 1000:
hm_modent_getentityparent comps 1000 subsystems
   # Handle error
Version History
2020
