hm_getcentroid
Returns the geometric centroid for selected entities.
hm_getcentroid entity_type mark_id
HyperMesh Tcl Query Command
entity_type
The type of entity to query. Valid values are surfaces and solids.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
To get the centroid of all surfaces:
*createmark surfs 1 all
hm_getcentroid surfs 1
   # Handle error
Version History
12.0.110
