hm_convertFromOutFileToDatFile
Generates a DAT file from an OUT file.
hm_convertFromOutFileToDatFile file_name
HyperMesh Tcl Query Command
The OUT file will be read and flutter summary data is collected, and the DAT file is generated in the same directory.
file_name
The name and path of the OUT file.
To convert the file C:/temp/flutter.out:
hm_convertFromOutFileToDatFile "C:/temp/flutter.out"
   # Handle error
Version History
2019.1
