hm_convertmarktorange
Converts a mark to an ID range and returns the ID range list with comma separators.
hm_convertmarktorange entity_type mark_id
HyperMesh Tcl Query Command
entity_type
The entity type of the mark to convert.
mark_id
The ID of the mark to convert. Valid values are 1 and 2.
Examples
To return all nodes on mark 1 as an ID range:
*createmark nodes 1 all
hm_convertmarktorange nodes 1
   # Handle error
Version History
2019
