hm_setsolver
Sets theHyperMesh solver interface name in order to access entity information available for that solver.
hm_setsolver name
HyperMesh Tcl Query Command
name
Solver name keyword:
  • abaqus
  • ansys
  • autodv
  • dytran
  • hyperopt
  • ideas
  • lsdyna
  • marc
  • masterfile
  • moldflow
  • nastran
  • optistruct
  • pamcrash
  • pamcrash2g
  • patran
  • pdm
  • phlex
  • simex
Examples
Suppose LS-DYNA solver template is actually loaded here:
set loadedsolver [ hm_getsolver ];
Getting attributes for OptiStruct:
hm_setsolver optistruct;
set opt_thickness [ hm_getvalue comps id=3 dataname=PSHELL_T];
Resetting back to the original solver name:
hm_setsolver $loadedsolver;
Note: This command does not actually load the solver template. It is intended only to temporarily switch solver type, get attribute information, and reset the solver name back to the original name.This operation is typically required during conversion between solvers.
None.
