hm_modent_getmodifiedbyids
Returns a list of modular entities modified after a representation has been realized.
hm_modent_getmodifiedbyids entity_type mark_id
HyperMesh Tcl Query Command
entity_type
The modular entity type. Currently only supported for subsystems.
mark_id
The ID of the mark containing the modular entities. Valid values are 1 and 2.
Examples
To get the list of subsystems modified after a representation has been realized:
*modent_addrepresentations subsystems 3 "crash5" "C:/representations/Subsystem1_Crash5mm.k " "Ls-Dyna"
*modent_realizerepresentation subsystems 3 "crash5"
*createmark comps 1 “by id only” 1 2 3
*modent_addcontentsbymark subsystems 3 comps 1
hm_modent_getmodifiedbyids subsystems 1
   # Handle error
Version History
2020
