*component()
Creates a component in HMASCII format.
*component (id,"name",materialid,color,propertyid)
HyperMesh HMASCII Command
Elements and geometry must be created within a component. Therefore, those respective entities must follow *component(). Master and slave elements must be created within a group, not a component.
id
The ID of the component.
name
The name of the component
materialid
The ID of the material assigned to the component.
color
The color of the component. Valid values are 1-64.
propertyid
The ID of the property assigned to the component. This is used only for HMASCII version 10.0 and greater.
To create a component with ID 100, name "my-comp", material ID 5, color 1 and no property:
*component(100,"my-comp",5,1,0)
Incorrect usage results in an import error.
