*bar3()
*bar3 (id type node1 node2 node3 propertyid dofsa dofsb localyz localyy localyz offsetax offsetay offsetaz offsetbx offsetby offsetbz directionnodeid directionnodeydir)
HyperMesh HMASCII Command
id
The ID of the element (must be unique).
type
The element type.
node[1,2,3]
The node IDs of the element.
propertyid
The ID of the property (must be a valid property or 0).
dofsa
The active degrees of freedom at end a.
dofsb
The active degrees of freedom at end b.
localyx, localyy, localyz
Make up the local y axis vector.
offsetax, offsetay, offsetaz
Make up the offset vector at end a.
offsetbx, offsetby, offsetbz
Make up the offset vector at end b.
directionnodeid
The ID used to specify the y or z axis. 0, if not used.
directionnodeydir
1, if the node specifies y axis direction.
0, if the node specifies z axis direction.
None.
