*set()
Creates a set in HMASCII format.
*set (id,"name",color,"type",ordered)
HyperMesh HMASCII Command
Creates a set in HMASCII format. To add entities to a set, use the *setid() command.
id
The ID of the set.
name
The name of the set.
color
The color of the set. Valid values are 1-64.
type
The type of the set. Valid values are nodes, elems, comps, sets, props, mats, assems, multibodies, ellipsoids, mbjoints and mbplanes.
ordered
Set to 0 for non-ordered sets and to 1 for ordered sets.
To create an non-ordered element set named plate_elems with ID 100 containing elements 50-52:
*set(100,"plate_elems",5,"elems",0)
*setid(50)
*setid(51)
*setid(52)
Incorrect usage results in an import error.
