*plotborder()
*plotborder (on color width margin xmin xmax ymin ymax)
HyperMesh HMASCII Command
on
1 if the border is on, 0 if off.
color
The color of the border. Refer to the color variable chart.
width
The width of the border in pixels (either 1 or 3).
margin
The margin between the border and the plot axes in pixels.
xmin
The x value of the upper left plot window (0.0 - 1.0).
xmax
The x value of the lower right plot window (0.0 - 1.0).
ymin
The y value of the upper left plot window (0.0 - 1.0).
ymax
The y value of the lower right plot window (0.0 - 1.0).
This command must follow a *plot() command.
None.
