*outputrequests()
Creates an outputrequest in HMASCII format.
*outputrequests (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the outputrequest.
name
The name of the outputrequest.
color
The color of the outputrequest. Valid values are 1-64.
To create a outputrequest with ID 100, name "my-entity", and color 1:
*outputrequests(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
