*structuralproperties()
Creates a structuralproperty in HMASCII format.
*structuralproperties (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the structuralproperty.
name
The name of the structuralproperty.
color
The color of the structuralproperty. Valid values are 1-64.
To create a structuralproperty with ID 100, name "my-entity", and color 1:
*structuralproperties(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
