*masses()
Creates a mass entity in HMASCII format.
*masses() (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the mass.
name
The name of the mass.
color
The color of the mass. Valid values are 1-64.
To create a mass entity with ID 100, name "my-entity", and color 1:
*masses(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017.2
