*flux()
Creates a flux load in HMASCII format.
*flux (id,type,entity_type,entity_id,systemid,flux)
HyperMesh HMASCII Command
Creates a flux element in HMASCII format.
This must follow *loadcollector(). The load will be assigned to the most recent collector created using *loadcollector().
id
The ID of the load.
type
The solver specific load type.
entity_type
An integer indicating the entity type the load is applied to.
entity_id
The ID of the entity the load is applied to.
systemid
The ID of the system assigned to the load. If specified as 0, there is no assigned system.
flux
The flux value assigned to the load.
To create a flux load with ID 100, solver type 1, attached to element 10, no system, and a flux of 2.0:
*flux(100,1,2,10,0,2.0)
Incorrect usage results in an import error.
