*temperature()
*temperature (id type locationid inputsystemid temperature)
HyperMesh HMASCII Command
id
The ID of the load (must be unique).
type
The load type.
locationid
The node ID where the load is applied.
inputsystemid
The reference coordinate system of the load (must be a valid system or 0).
temperature
The applied temperature.
None.
