*metadata_date()
Creates date metadata in HMASCII format.
*metadata_date (entity_type,entity_id,"name",value)
HyperMesh HMASCII Command
entity_type
An integer indicating the type of entity the metadata is attached to. A value of undef indicates attachment to the database itself.
entity_id
The ID of the entity the metadata is attached to. Ignored if entity_type is undef.
name
The name by which the metadata will be referenced.
value
The date value assigned to the metadata. This is the number of seconds since the epoch (i.e., January 1st 00:00:00 1970).
To create data metadata attached to element ID 100, with name "my-date" and the date as January 1st 00:00:00 2011:
*metadata_date(2,100,"my-date",1293858000)
Incorrect usage results in an import error.
