*dependentnodes()
*dependentnodes (node1 node2 node3 etc)
HyperMesh HMASCII Command
node[1 to n]
The ID of the dependent node.
This command must immediately follow a *rigidlink() definition. There must be as many nodes defined as stated in the *rigidlink command.
None.
