*seatbeltcontrolpoints()
Creates a seatbeltcontrolpoint in HMASCII format.
*seatbeltcontrolpoints (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the seatbeltcontrolpoint.
name
The name of the seatbeltcontrolpoint.
color
The color of the seatbeltcontrolpoint. Valid values are 1-64.
To create a seatbeltcontrolpoint with ID 100, name "my-entity", and color 1:
*seatbeltcontrolpoints(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
