*joints()
Creates a mechanism joint in HMASCII format.
*joints (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the joint.
name
The name of the joint.
color
The color of the joint. Valid values are 1-64.
To create a joint with ID 100, name "my-entity", and color 1:
*joints(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.120
