*modelcheckchecks()
Creates a model check check in HMASCII format.
*modelcheckchecks (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the model check check.
name
The name of the model check check.
color
The color of the model check check. Valid values are 1-64.
To create a model check check with ID 100, name "my-entity", and color 1:
*modelcheckchecks(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
