*plotgrid()
*plotgrid (lines xincrement yincrement mindivisions maxdivisions color xlabel ylabel width)
HyperMesh HMASCII Command
lines
1, if grid lines are on, 0, if off.
xincrement
The increment size of grid lines on the x axis.
yincrement
The increment size of grid lines on the y axis.
mindivisions
The minimum number of grid divisions allowed.
maxdivisions
The maximum number of grid divisions allowed.
color
The color of the grid lines. Refer to the color variable chart.
xlabel
The x grid label frequency.
ylabel
The y grid label frequency.
width
The width of the grid lines in pixels (either 1 or 3).
This command must follow a *plot() command.
None.
