*connectorsets()
Creates a connectorset in HMASCII format.
*connectorsets (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the connectorset.
name
The name of the connectorset.
color
The color of the connectorset. Valid values are 1-64.
To create a connectorset with ID 100, name "my-entity", and color 1:
*connectorsets(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
