*alesmoothings()
Creates an alesmoothing in HMASCII format.
*alesmoothings (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the alesmoothing.
name
The name of the alesmoothing.
color
The color of the alesmoothing. Valid values are 1-64.
To create an alesmoothing with ID 100, name "my-entity", and color 1:
*alesmoothings(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
