*icelink()
Defines the independent nodes for an IC element in HMASCII format.
*icelink (independentnodeid,dependentnodesmax,dependentnodeid_1,dependentdof_1,...,dependentnodeid_N,dependentnodedof_N)
HyperMesh HMASCII Command
This must follow *ice(). The definition applies to the most recent IC created using *ice().
Nodes must also be defined using *node() before creating an element using those nodes.
independentnodeid
The ID of the independent node to add.
dependentnodesmax
The number of dependent nodes associated with the independent node.
dependentnodeid_N
The dependent node ID. This is repeated along with dependentnodedof_N for each dependent node.
dependentnodedof_N
The dependent node DOF. This is repeated along with dependentnodeid_N for each dependent node.
To create an IC element with ID 500, independent nodes 100 and 101, node 100 dependent nodes 200 and 300 with DOF 12, and node 101 dependent nodes 201 and 301 with DOF 123:
*ice(500,0,2,4)
*icelink(100,2,200,12,300,12)
*icelink(101,2,201,123,301,123)
Incorrect usage results in an import error.
Version History
14.0
