*blockwall()
*blockwall (id name color)
HyperMesh HMASCII Command
id
The ID of the wall (must be unique).
name
The name of the wall.
color
The color of the wall. Refer to the color variable chart..
A block may have any number of walls. Wall definitions must follow the *block() command.
None.
