*directmatrixinputs()
Creates a direct matrix input in HMASCII format.
*directmatrixinputs() (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the direct matrix input.
name
The name of the direct matrix input.
color
The color of the direct matrix input. Valid values are 1-64.
To create a direct matrix input with ID 100, name "my-entity", and color 1:
*directmatrixinput(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017
