*positions()
Creates a position in HMASCII format.
*positions (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the position.
name
The name of the position.
color
The color of the position. Valid values are 1-64.
To create a position with ID 100, name "my-entity", and color 1:
*positions(100,"my-entity",1)
Incorrect usage results in an import error.
