*alereferencesystemnodes()
Creates an alereferencesystemnode in HMASCII format.
*alereferencesystemnodes (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the alereferencesystemnode.
name
The name of the alereferencesystemnode.
color
The color of the alereferencesystemnode. Valid values are 1-64.
To create an alereferencesystemnode with ID 100, name "my-entity", and color 1:
*alereferencesystemnodes(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
