*property()
Creates a property in HMASCII format.
*property (id,"name",materialid,color)
HyperMesh HMASCII Command
Property data is assigned using attributes for the relevant solver.
id
The ID of the property.
name
The name of the property.
materialid
The ID of the material assigned to the property.
color
The color of the property. Valid values are 1-64.
To create a property with ID 100, name "my-prop", material ID 5 and color 1:
*property(100,"my-prop",5,1)
Incorrect usage results in an import error.
