*symmetrypivots()
Creates a symmetrypivot in HMASCII format.
*symmetrypivots (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the symmetrypivot.
name
The name of the symmetrypivot.
color
The color of the symmetrypivot. Valid values are 1-64.
To create a symmetrypivot with ID 100, name "my-entity", and color 1:
*symmetrypivots(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019.1
