*hourglass()
Creates an hourglass in HMASCII format.
*hourglass() (id, name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the hourglass.
name
The name of the hourglass.
color
The color of the hourglass. Valid values are 1-64.
To create an hourglass with ID 100, name "my-entity", and color 1:
*hourglass(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017.1
