*failures()
Creates a failure in HMASCII format.
*failures (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the failure.
name
The name of the failure.
color
The color of the failure. Valid values are 1-64.
To create a failure with ID 100, name "my-entity", and color 1:
*failures(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
