*xelem()
Creates an xelem element in HMASCII format.
*xelem (id,type,dependentnodeset,dependentnodesmax)
HyperMesh HMASCII Command
This must follow *component(). The element will be assigned to the most recent component created using *component().
A *dependentnodes() description must immediately follow.
Nodes must also be defined using *node() before creating an element using those nodes.
id
The ID of the element.
type
The solver specific element type.
dependentnodeset
The ID of the dependent node set.
dependentnodexmax
The number of dependent nodes in the set.
To create an xelem element with ID 100, solver type 1, and node set 10 with 4 nodes:
*xelem(100,1,10,4)
Incorrect usage results in an import error.
Version History
2019
