*material()
Creates a material in HMASCII format.
*material (id,name,color)
HyperMesh HMASCII Command
Material data is assigned using attributes for the relevant solver.
id
The ID of the material.
name
The name of the material.
color
The color of the material. Valid values are 1-64.
To create a material with ID 100, name "my-mat" and color 1:
*material(100,"my-mat",1)
Incorrect usage results in an import error.
