*attributeentity()
*attributeentity (type value identifier behavior status solver)
HyperMesh HMASCII Command
type
The type of the entity that is contained in the attribute (i.e., prop, elem).
value
The ID of the entity that is attached to the preceding entity.
identifier
The number of the attribute in the corresponding solver.
behavior
The behavior flag for the attribute.
status
The status for the attribute.
solver
The solver number for the attribute.
Incorrect usage results in an import error.
