*responses()
Creates a response in HMASCII format.
*responses (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the response.
name
The name of the response.
color
The color of the response. Valid values are 1-64.
To create a response with ID 100, name "my-entity", and color 1:
*responses(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2020
