*interfacepairmax()
Defines the number of interface pairs assigned to a sub-laminate laminate.
*interfacepairmax (count)
HyperMesh HMASCII Command
count
The number of interface pairs assigned to a sub-laminate laminate.
Examples
To create a sub-laminate laminate with ID 300, name "my-sub-laminate-laminate" and sub-laminates 200 and 201:
*laminates(200,"my-sub-laminate-laminate",1,0,1,0)
*laminateidlistmax(2)
*laminateidlist(200,201)
To add an interface to the above laminate:
*interfacepairmax(1)
*interfacepairlist(200,201)
Incorrect usage results in an import error.
Version History
11.0
