*constraints()
Creates a mechanism constraint in HMASCII format.
*constraints (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the constraint.
name
The name of the constraint.
color
The color of the constraint. Valid values are 1-64.
To create a constraint with ID 100, name "my-entity", and color 1:
*constraints(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.120
