*regions()
Creates a region in HMASCII format.
*regions (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the region.
name
The name of the region.
color
The color of the region. Valid values are 1-64.
To create a region with ID 100, name "my-entity", and color 1:
*regions(100,"my-entity",1)
Incorrect usage results in an import error.
