*tagdescription()
Assigns a text description to a tag in HMASCII format.
*tagdescription (id,"description")
HyperMesh HMASCII Command
id
The ID of the tag.
description
A quoted string containing the text description.
To create a tag with ID 100 and name Bushing:RightFront attached to node 500, with a description of "Node for right front-bushing.":
*tag(100,500,1,3,"Bushing","RightFront")
*tagdescription(100,"Node for right-front bushing.")
Incorrect usage results in an import error.
Version History
11.0.130
