*constrainedextranodes()
Creates a constrainedextranode in HMASCII format.
*constrainedextranodes (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the constrainedextranode.
name
The name of the constrainedextranode.
color
The color of the constrainedextranode. Valid values are 1-64.
To create a constrainedextranode with ID 100, name "my-entity", and color 1:
*constrainedextranodes(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0
