*master3()
Creates a master3 element in HMASCII format.
*master3 (id,type,node1,node2,node3)
HyperMesh HMASCII Command
This must follow *group(). The element will be assigned to the most recent group created using *component().
Nodes must also be defined using *node() before creating an element using those nodes.
id
The ID of the element.
type
The solver specific element type.
node1
The ID of the first node.
node2
The ID of the second node.
node3
The ID of the third node.
To create a master3 element with ID 100, solver type 1 and nodes 1 3 2:
*master3(100,1,1,3,2)
Incorrect usage results in an import error.
