*inodes()
Defines the independent nodes for an equation load.
*inodes (id1,id2,...,idN)
HyperMesh HMASCII Command
The *equation(), *inodes(), *idofs() and *icoeffs() blocks must be in the following order:
  • *equation()
  • *inodes()
  • *idofs()
  • *icoeffs()
ids
The IDs of the independent nodes.
To create an equation with ID 300, type 1, constant 2.5, independent nodes 5-7 with DOFs 1, 3 and 5 and coefficients of 0.5 for all DOFs, and dependent node 350 with DOF 3 and coefficient 2.0:
*equation(100,1,2.5,3,350,3,2.0,5)
*inodes(5,6,7)
*idofs(135,135,135)
*icoeffs(0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5)
Incorrect usage results in an import error.
