*retractors()
Creates a retractor in HMASCII format.
*retractors (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the retractor.
name
The name of the retractor.
color
The color of the retractor. Valid values are 1-64.
To create a retractor with ID 100, name "my-entity", and color 1:
*retractors(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2017.1
