*aletanktests()
Creates an aletanktest in HMASCII format.
*aletanktests (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the aletanktest.
name
The name of the aletanktest.
color
The color of the aletanktest. Valid values are 1-64.
To create an aletanktest with ID 100, name "my-entity", and color 1:
*aletanktests(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2019
